I just updated to 0.96, and made the climate changes from operation_mode to hvac_mode. I use AppDaemon to set the temperature on a nest thermostat and a radio therm thermostat. I use the call:
self.call_service('climate/set_temperature', entity_id=therm_name, temperature=target)
Where therm_name=‘climate.nest_name’ and target is a float value.
This call works fine on the radio therm, but doesn’t do anything on the nest following the update to 0.96. Not even an error.
Worked on both prior to 0.96.
Thoughts?
