Nest was working on 2023.2.4. Updated to .5, rebooted and Nest entities are unavailable. reloading integration or total system reboot doesn’t resolve.
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
From the logs:
2023-02-16 18:52:23.786 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ '%0.1f'|format(state_attr('climate.hallway', 'temperature')) }}")
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 457, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1984, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.10/site-packages/jinja2/filters.py", line 1002, in do_format
return soft_str(value) % (kwargs or args)
TypeError: must be real number, not NoneType
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 575, in async_render_to_info
render_info._result = self.async_render(variables, strict=strict, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 459, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: TypeError: must be real number, not NoneType
2023-02-16 18:52:23.794 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError('TypeError: must be real number, not NoneType') while processing template 'Template("{{ '%0.1f'|format(state_attr('climate.hallway', 'temperature')) }}")' for attribute '_attr_native_value' in entity 'sensor.hallwaynest_target'
