Nest Thermostat doesn't work properly since integration
I did the whole Nest integration in Home Assistant (correctly) but since the integration, the Nest thermostat loses the connection with the app and also appears network problems in the thermostat.
Trying to debug the problem, I see a lot of errors in the pub/sub:
moreover, a non-sense latency in 95% percentile (as you can see in the image).
The errors have 499 and 503 codes.
