I am using the official Nest integration and have added my Nest thermostat to Home Assistant. I have a fan schedule setup through the Google Home app which will run the fan on my furnace for at least 30 minutes out of every hour.
The problem I am having is that Home Assistant does not display nor give any indication when the fan is running via this schedule (although it will display when I manually turn on the fan).
Is this a known bug? Any fix?
