EDIT: Maybe linked to this Nest - Not returning device or entities · Issue #80675 · home-assistant/core · GitHub
Since update of HA to 2022.10.5 the Nest Thermostat is gone.
Use the Google Integration and not the WWN way.
Removed everything to create whole new OAuth etc… But when I click on this button:
I come to a screen and the URL is showing me this:
https://nestservices.google.com/partnerconnections/< SNAP>/auth?response_type=code&client_id=<SNAP>&redirect_uri=http://192.168.100.24:8123/auth/external/callback&state=<SNAP>&scope=https://www.googleapis.com/auth/sdm.service+https://www.googleapis.com/auth/pubsub&access_type=offline&prompt=consent
As you can see my local URL is in the link http://192.168.100.24:8123
That will never work I guess
In tutor it say you have to fill in Link to OAuth2 Authorize Callback – My Home Assistant
in credentials on Google Cloud. ( I tried also my URL to access HA from outside) and both not work.
I really don’t know what to do…
Also see this error in log:
2022-10-21 16:30:03.793 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 171, in get
return await super().get(request, flow_id)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 96, in get
result = await self._flow_mgr.async_configure(flow_id)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 280, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 303, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(self.external_data)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 169, in async_resolve_external_data
return await self._token_request(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 205, in _token_request
resp.raise_for_status()
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 1004, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request', url=URL('https://www.googleapis.com/oauth2/v4/token')
