I have a Nest thermostat integrated into HA. I use AppDaemon to adjust the thermostat during the day, when we’re out of the house, at night, etc. The call is:
self.call_service(service, **proper_args)
Where proper_args
is:
{'entity_id': 'climate.hallway', 'temperature': 69.0, 'hvac_mode': 'heat'}
The service call is: climate/set_temperature
This works most of the time, but every now and then the climate card in the UI shows the system is off
the actual thermostat is still on
. I looked in the logs and the output for the last 12 hours are:
Hallway changed to Heat triggered by service Climate: Set HVAC mode
9:47:28 AM - 14 minutes ago - kirby
Hallway turned off
9:00:14 AM - 1 hour ago
Hallway turned off
Hallway changed to Heat triggered by service Climate: Set target temperature
5:06:04 AM - 5 hours ago - Supervisor
December 19, 2023
Hallway turned off triggered by service Climate: Set target temperature
9:00:05 PM - 13 hours ago - Supervisor
The first (latest) entry is when I used the UI card to turn the thermostat back on. The 2 entries at 09:00:14 are when the set_temperature
service was called to adjust the thermostat. The next two entries at 5:06:04 are when ONE service call was also made. The UI card didn’t turn off.
And then, going back to last night at 9:00:05 pm, the scheduled service call turned off the UI card thermostat. But interestingly, it did set the thermostat properly (sets back to 64).
Does anyone notice anything similar?
