Unfortunately I’ve started with this issue too, the integration has been a little flakey with 400 errors when moving between ECO and heat. This morning every change of mode threw a 400, rebooted the HA server and the thermostat is now unavailable in HA.
I tend to try to find work arounds for these things but what I’ve found is maybe a little more concerning. I also use SmartThings as a ZWave and Zigbee controller. I have tried to add Nest back into ST using the official integration (so not using the HA Auth) and it would appear that ST can’t see my Thermostat after a successful setup. I also read that Alexa integration is broken, but haven’t tested.
I’m going to experiment with triggering the mode change by sharing a device between HA and Google home and turning it on and off using the status of an on/off device. A hack but at least it should get the heat back on!!
Absolute pain that this integration has broken during the worst energy crisis for a generation.
My guess is it’s because google is getting ready to go live with accessing your google devices from the web browser “next week” through the home.google.com website. Either API changes, or a new Google API replacing the Nest API.
I’m getting this issue as of today.
The state of thermostat is correct on HA but I can’t change HVAC mode or temperature getting a 400 on both.
Anybody seeing this again?
Yes, mine has been unreliable all day, if I try to set a target temperature via HA it simply turns the stat off, same if I issue a command via Alexa, more reliable through Google Home but still not great. been working fine up until the last 24 hrs…
