Hello all,
I’ve noticed that there is a lot of information shown in the App for the Nest Thermostat.
Also there is an option for Fan which i don’t really understand. For me there is no Fan with my thermostat.
Maybe remove the box from the screen?
Is it also possible to remove the greyed out data from the screen and only have the functional bits displayed?
For the temperature slider the text “temperature” overlaps with the actual currently set degrees.
Could you move the degrees to the right side of the screen rather then under the text?
I’ve several Apple devices to test your app on and i tested this on a iPhone SE.
Will have a look on the iPhone 6 and 6S to see if there is any difference.
Haven’t been able to test the App on iPads. Can i just install Testflight and use the link again for those devices? (mini, air and pro)
Thanks again for letting me testdrive the app.
I finally found a decent domotica system with a nice app Keep up the good work.
Joop
