Hi Guys
What’s peoples opinions on nest vs hive in regards to hassio. Can you use hassio to set the thermostat temperature?
My intention is to upgrade my TRV’s to eurotronic-spirit-smart-radiator-thermostats and *install either a nest or hive thermostat to control the boiler.
My understanding is that the eurotronic-spirit TRV will post the room temperature to hassio.
Therefore as an example if my kids room got too cold in the night I should in theory be able to detect it and send an instruction to override the thermostat (nest/hive) temperature to turn on the boiler which will then heat up that individual room or any room’s TRV that hasn’t reach it set temperature?
