(Nested) Group showing with a toggle..? (and not state Home/Away)
having not used 2 groups in my Lovelace frontend before (only used them for backend logic) Ive now added them to a card, and am surprised to see them having a toggle, and not showing the state. Is this to be expected?
lovelace:
  - type: entities
    title: At home
    entities:
      - entity: binary_sensor.family_home
        secondary_info: last-changed
      - entity: sensor.family_home
      - type: divider
      - entity: group.family
      - entity: group.family_home
      - type: divider
      - entity: binary_sensor.daughters_home
      - entity: sensor.daughters_home
      - type: divider
      - entity: group.daughters
      - entity: group.daughters_home
the 2 groups are defined as:
  family_home:
    icon: mdi:home-heart
    entities:
      - group.daughter_1
      - group.daughter_2
      - group.daughter_3
      - group.daughter_4
      - group.she
      - group.me
and
  daughters_home:
    icon: mdi:human-child
    entities:
      - group.daughter_1
      - group.daughter_2
      - group.daughter_3
      - group.daughter_4
(… edited the actual names :wink: )
of course these groups exist of yet multiple entities again)
why the toggle, because when toggling an error is displayed it cant find a service device_tracker/turn_on, which is correct of course. and, though the toggle does change position, the entity doesnt change state.
so, I am somewhat confused…
  - type: entities
    title: At home
    show_header_toggle: false
    entities:
      - type: divider
      - type: divider
      - type: divider
ha yes, I know that’s for the group toggle in the title of the card. I meant the 2 individual toggles for group.family_home and group.daughters_home though. They are groups, and I can not toggle them…
I think it depends on what the group contains. All of these are groups:
Screenshot_2020-06-10 Administration - Home Assistant
The middle one is a group of binary sensors, so no toggle.
I can toggle the ones that have them.
yes, that’s what I thought. Standard behavior.
These groups only contain device_trackers though… as is reflected in the error I get when trying to toggle.
as you can see the entities just above the toggled ones, show Home just as I would expect them to, these also are groups, but with individual device_trackers. (btw, these device_trackers are of the composite integration, so contain several trackers themselves …;=)
still experiencing this without a hunch of an idea where to find a solution…
Actually from what you posted those groups contain groups.
Did you open an issue?
I was referring to the groups within the groups. The group with the toggles indeed contain only groups.
No, I didn’t yet file an issue
That’s how you get it looked at. You know that buddy.
ok. if have now: group with nested groups shows toggle instead of state home/not_home · Issue #6599 · home-assistant/frontend · GitHub
