I’m wondering if it’s possible to have a nested secrets structure? I quickly tried and it seems HA couldn’t handle it.
If not, consider this a feature request
What I had in mind is something like the variables in flexget (https://flexget.com/Plugins/variables)
Basically what it boils down to, is having the following structure in the secrets:
This brings off course a little extra typing work, but in my opinion, it is a lot easier this way, to keep track off all the secrets, and nicely bundle them together in a structured way. Those not wanting to use this feature, can still define them as flat keys and they would still work.
From what I can see you’ve taken what is currently 3 easy lines in the secrets file, and turned them into 5 not so easy lines with the added complication of the references being more obscure.
Perhaps I missed something but I can’t see any advantage to this over the current approach.
Well, at first I had my secrets all named with either all lowercase or camelcase, which was getting hard to read. Even tried using underscores but still wasn’t to my liking.
I am now using the same structure with the dot in the middle, but got them named exactly the same in my secrets file. This way it more resembles closely a JSON structure, which makes a lot of sense for me, seeing as you can more easily group related stuff together.
What you mentioned is true, it does add complexity to the structure, for now the flat dot notations I use are sufficient enough for me
I second this as well. I’m used to working with YAML variable files that allow nesting and was surprised that HA could not parse as I was cleaning up my config repo.
