Hi there:
I am trying to do the following:
I need to loop over all sensors states and, for those with a specific string in their entity_id, I need to get the state and some other attributes.
(FYI My devices names are standardize )
If I try this:
{% for state in states -%}
{% if (state.entity_id.split("_")[2]) == 'whatever' %}
{{states('{{state.entity_id}}')}}
{% endif %}
{%- endfor %}
I just get unknown for every device although I know that the {{state.entity_id}} is properly converted (just put it there and it returns the entity_id for each device entering the if block). If I check each one with its own entity_id I get a proper state reply.
Any suggestion?
Thanks a lot.
Thanks mate!
BTW, I was hoping I could automatically get the last_updated from the zwave smartplug linked to each of those devices with something like this
{{ states.zwave.smart_plug_{{state.entity_id.split("_")[3]}}.last_updated }}
but it doesn’t seem to work (although states.zwave.smart_plug{{state.entity_id.split("")[3]}} creates the proper string)
Any idea how to do that?
Super cool. Thanks a lot.
Important question: I’ve been googling but I can’t find a place where that kind of info is properly explained… Any suggestion?
I mean. I haven’t seen any zwave["smart_plug"~_ notation anywhere,
An attribute (especially in Jinja) can be accessed two ways: X.Y, or X['Y']. The former is more common, and the latter is usually used when the attribute name starts with a digit. (E.g., you can’t do X.1, so you have to do X['1'].) But the latter comes in handy for this sort of thing, too.
The tilda (~) operator is documented in the Jinja docs. It takes its two operands, converts them to strings if necessary, and then concatenates them. In this case you could have just used +, but in Jinja ~ is preferred.
Basically, you just have to read the docs. This is probably the best place to start.
