However HA always has issues with the netatmo component
2019-02-22 13:35:42 ERROR (MainThread) [homeassistant.setup] Error during setup of component netatmo
File "/usr/src/app/homeassistant/setup.py", line 154, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/src/app/homeassistant/components/netatmo/__init__.py", line 48, in setup
'read_station read_camera access_camera '
File "/usr/local/lib/python3.7/site-packages/pyatmo.py", line 85, in __init__
self._accessToken = resp["access_token"]
TypeError: 'NoneType' object is not subscriptable
2019-02-22 13:35:42 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of netatmo.sensor. Setup failed for dependencies: netatmo
2019-02-22 13:35:42 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform netatmo.sensor: Could not set up all dependencies.
2019-02-22 13:35:42 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function EventBus.async_listen_once.<locals>.onetime_listener at 0x7f70a036dd90>
Does your fix work if one has no stations?
According to this document
