Hi everyone,
I have a Netatmo thermostat and it used to work great with Home Assistant. I moved a couple of months ago and I am now trying to set up my home assistant instance from scratch. So far everything is working, except the Netatmo integration for my thermostat.
In the configuration.yaml I have set up:
netatmo:
client_id: !secret netatmo_client_id
client_secret: !secret netatmo_client_secret
I checked, and the client id and secret are still correct.
Then, when I try to add the Netatmo component via the frontend, it just tells me āAbortedā, however there are no error logs in the log file and no other indication what is wrong.
I have tried taking the code away from the configuration.yaml, when I then try to add the integration, it does say that it needs the code in the config file to workā¦
What am I doing wrong?
Iām running Home Assistant 0.115.6.
