NetAtmo base module sensors lost since upgrade 0.101.2 < 0.102.X
Since upgrading from 0.101.2 to 1.102.b1 my NetAtmo Base module sensors are lost.
I’m still migrating from Domoticz to HA so I can compare the 2 systems how the are working with NetAtmo. My Domoticz system is still reading all available modules, HA is missing the base unit sensors.
I see no relevant errors in my logbook, tried removing the config line of NetAtmo from configuration.yaml and reload HA, but this didn’t help. Then I tried to reset the OAuth at NetAtmo and reload the new keys on HA, but this didn’t help either. Tried to rename sensors, didn’t help…
So I’m out of options…
Anybody here with the same issue and/or has an idea to solve this?
Same problem here after upgrading to 0.102
Same here but it seems that there is already a PR in dev branch to fix the issue, opened by @cgtobi.
Same here after upgrading to 0.102
@cgtobi will this fix be included in 0.102.1?
I have exactly the same problem. The base station disappeared in HA after the upgrade, but all other modules (indoor, outdoor, wind, and rain) seem to work fine.
I can’t promise but the chances are good that it will ship soon.
PR is merged, so it should ship with the next release.
I noticed the merge this afternoon! Thanks for the great work and quick action!
Please update to 0.102.1 to fix the issue. It has just been released.
@cgtobi with 0.102.1 my entities reappered but now all of them show “unknown” as their state.
entities like like the co2 sensors worked fine with 0.102. Now they are unknown too.
Tried restarting ha and the netatmo heater station.
Having the same issue with 0.102, ie the sensors from the base station (co2, noise level, T°, …) are in unknown state while the sensors from the external module are OK.
Will wait to see @h4nc’s feedback on 0.102.1 before pushing the upgrade button…
I’m already at it. Thanks for reporting.
Confirmed solved with 0.102.1, I got all my netatmo sensors back and working.
Thanks !
To bad! The problem still exists. I have 0.102.1 and still no sensors.
The problem with manual config should be fixed with https://github.com/home-assistant/home-assistant/pull/28956
Yes, strange indeed. Right after upgrading to 0.102.1 I got all the netatmo sensors back and showing correct values, than after a HA restart they all went to unknown state.
Do you use discovery in your netatmo config? Or do you configure your components manually?
Here I see some inconsistency in sensor names.
I’m using discovery and my base unit sensor are shown as
“sensor.netatmo_s80_wk_"
"sensor.netatmo_indoor_
such as;
sensor.netatmo_indoor_wifi
sensor.netatmo_s80_wk_noise
Very strange.
Sorry, could you please explain what’s old and new? And what you’d expect or what has changed?
Did you already find the reason for this?
