ok,
i have the same problem from time to time, I think its a wifi issue and netatmo issue.
if i change my wifi channel and sometimes back to the same channel - it works
strange !!!
in my router i have change 802.11 DTIM Period to 3 instead of 2.
hope you get it to work,
Did you succeed to get all your camera streaming ?
I tried about everything but still same issue
All my camera are streaming now but don’t know exactly the solution.
My router (DHCP) gives fixed IP adresses to my cameras. I tried changing ip adresses then rebooting router, HA & camera. That worked partially and intermittently.
Shortly after I rebooted the cameras from the Netatmo app. After less than an hour all camera are streaming.
I think the common point I have with you is the need to force disconnection of camera. In my case just cycling power was not enough, I’m wondering if the reboot command from Netatmo app was the solution.
I still have my router bypassing pi-hole. I’ll try tomorrow to put it back and see if cameras remain streaming.
Important to note that HomeKit and Netatmo server don’t lose connection with the cameras, so likely HA has trouble connecting to camera on LAN from the MAC adresses given by Netatmo server.
Thanks for your input
