Hi
I recveived an email from Netatmo regarding Client Credentials grant type method will be completely removed. I use the Netatmo climate control for my heating.
Is this something that I need to be worried about or has the Netatmo integration already been updated with this change in mind?
Netatmo API Security Update
Dear Netatmo developer,
To improve the security of our products, we inform you that the Client Credentials grant type method will be completely removed. It will no longer be possible to authenticate with the username and password of the user.
The effective date of this update is October 2022.
How can you authenticate with Netatmo API ?
From this date, the OAuth2 authorization code flow must be followed for authentication.
You can find details on this method on our website:
Netatmo Connect Authentication
For tests, you can also get an Access Token from our developper portal.
Netatmo Developer Portal
- Log in
- Go on your account
- Select the application for your test
- Click on “Generate a Token”
You can now use this Access Token for 3 hours.
Sincerely,
Legrand - Netatmo - Bticino
