After upgrading to 2021.12.10 my Netatmo Climate ceases to respond.
I got the followings in the log:
2022-01-22 09:31:50 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2022-01-22 09:31:50 WARNING (MainThread) [homeassistant.components.climate] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2022-01-22 09:31:51 WARNING (MainThread) [homeassistant.components.sensor] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2022-01-22 09:31:51 ERROR (MainThread) [homeassistant.components.select] Error while setting up netatmo platform for select
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/netatmo/select.py", line 52, in async_setup_entry
await data_handler.register_data_class(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 198, in register_data_class
await self.async_fetch_data(data_class_entry)
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 154, in async_fetch_data
await self.data[data_class_entry].async_update()
File "/usr/local/lib/python3.9/site-packages/pyatmo/climate.py", line 341, in async_update
self.process(raw_data)
File "/usr/local/lib/python3.9/site-packages/pyatmo/climate.py", line 299, in process
if self.home_id != raw_data["home"]["id"]:
KeyError: 'id'
Have restarted HA several time, same issue.
Could anyone help me to fix this, I really do not know what is the problem.
Thanks in advance.
Note that I have the issue only with Netatmo Thermostat, the Netatmo Cameras Presence and Welcome do respond normally. And also I have no issue accessing to Netatmo Thermostat using Netatmo Energie app or via the Web.
