I’ve the same ambient/netatmo configuration from a while, but since 0.93.2 my Netatmo component stop working few minutes after reboot then stop working again.
The stream to Netatmo it’s working, I’ve checked that all my data is present in the Netatmo server.
This is my log:
2019-05-27 10:44:35 ERROR (MainThread) [homeassistant.helpers.entity] Update for climate.netatmo_ingresso fails
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 220, in async_update_ha_state
await self.async_device_update()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 377, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 274, in update
self._data.update()
File "/usr/local/lib/python3.7/site-packages/homeassistant/util/__init__.py", line 224, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py", line 369, in update
self.homestatus = pyatmo.HomeStatus(self.auth, home=self.home)
File "/usr/local/lib/python3.7/site-packages/smart_home/Thermostat.py", line 153, in __init__
resp = postRequest(_GETHOMESTATUS_REQ, postParams)
File "/usr/local/lib/python3.7/site-packages/smart_home/__init__.py", line 39, in postRequest
if params
File "/usr/local/lib/python3.7/urllib/request.py", line 222, in urlopen
return opener.open(url, data, timeout)
File "/usr/local/lib/python3.7/urllib/request.py", line 525, in open
response = self._open(req, data)
File "/usr/local/lib/python3.7/urllib/request.py", line 543, in _open
'_open', req)
File "/usr/local/lib/python3.7/urllib/request.py", line 503, in _call_chain
result = func(*args)
File "/usr/local/lib/python3.7/urllib/request.py", line 1360, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/usr/local/lib/python3.7/urllib/request.py", line 1320, in do_open
r = h.getresponse()
File "/usr/local/lib/python3.7/http/client.py", line 1321, in getresponse
response.begin()
File "/usr/local/lib/python3.7/http/client.py", line 296, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.7/http/client.py", line 257, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.7/socket.py", line 589, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.7/ssl.py", line 1052, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.7/ssl.py", line 911, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
