Getting an error ever since updating to 0.65
First off it says it can’t load all dependencies and then throws this error:
ideas?
Error during setup of component netatmo
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
component.setup, hass, processed_config)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py", line 327, in __iter__
yield self # This tells Task to wait for completion.
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py", line 243, in result
raise self._exception
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/netatmo.py", line 55, in setup
'read_station read_camera access_camera '
File "/Users/mediacenter/.homeassistant/deps/lib/python/site-packages/lnetatmo.py", line 74, in __init__
self._accessToken = resp['access_token']
TypeError: 'NoneType' object is not subscriptable
