i’ve the Netatmo thermostat component running from a year… but now (without changing anything is not loading anymore)
i’ve tryed to disable autodiscovery but nothing changed… this is the component error log:
2017-08-06 18:20:37 ERROR (MainThread) [homeassistant.setup] Error during setup of component netatmo
File "/usr/lib/python3.4/urllib/request.py", line 1174, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "/usr/lib/python3.4/http/client.py", line 1090, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/usr/lib/python3.4/http/client.py", line 1221, in connect
super().connect()
File "/usr/lib/python3.4/http/client.py", line 836, in connect
self.timeout, self.source_address)
File "/usr/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/netatmo.py", line 55, in setup
'read_station read_camera access_camera '
File "/srv/homeassistant/lib/python3.4/site-packages/lnetatmo.py", line 71, in __init__
resp = postRequest(_AUTH_REQ, postParams)
File "/srv/homeassistant/lib/python3.4/site-packages/smart_home/__init__.py", line 27, in postRequest
resp = urllib.request.urlopen(req, params).read(body_size).decode("utf-8")
File "/usr/lib/python3.4/urllib/request.py", line 153, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.4/urllib/request.py", line 455, in open
response = self._open(req, data)
File "/usr/lib/python3.4/urllib/request.py", line 473, in _open
'_open', req)
File "/usr/lib/python3.4/urllib/request.py", line 433, in _call_chain
result = func(*args)
File "/usr/lib/python3.4/urllib/request.py", line 1217, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/usr/lib/python3.4/urllib/request.py", line 1176, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 111] Connection refused>
