Followed the instructuons regarding to how to integrate Netatmo, however there’s no result. I don’t understand either why should I add an api key to the config as the netatmo online service doesn’t offer any possibility to add Netatmo Home Coach as a device so I assume their online service tracks only weather stations.
Is there anyone out there who has no station, but only the Home Coach and was able to get this work with HA?
As I see it, our problem is the complete opposite. Home coach cannot be added if so not have a station. There’s no way to get to the web interface and obtain a token, if you only have a home coach. When trying, you just get a prompt to add a station.
You can have an API from the dev.netatmo website. The fact the cloud does not includes home coach is another matter.
However I can’t add home coach at all (despite having API secret which I tested and is working): auto discovery fails to add anything and manually : impossible to add any module in the sensor config … since home coach does not have any modules.
unfortunately, I’m stuck on this also. Having Home Coach App on iOS, it’s connected with my mail address and receives data from my home coach every n minutes. When I’m logged in on netatmo dot com, I have „no devices connected“ and my home coach does not show up any more (just a pop-up that allows me to add anything except a Home Coach). As this is the way suggested in component documentation, things seem to have changed – I’m using this device for months now and I’m pretty sure I could see it’s data on netatmo dot com (probably before Netatmo belonged to Legrand??).
Autodiscovery indeed fails. When deactivating the app on dev.netatmo.com, at least I get an error message in home-assistant.log:
Feb 19 22:36:47 leinen hass[7039]: #033[31m2019-02-19 22:36:47 ERROR (MainThread) [homeassistant.setup] Error during setup of component netatmo#033[0m │
Fe│Feb 19 22:36:47 leinen hass[7039]: Traceback (most recent call last): │
Fe│Feb 19 22:36:47 leinen hass[7039]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 148, in _async_setup_component │
Fe│Feb 19 22:36:47 leinen hass[7039]: component.setup, hass, processed_config) # type: ignore │
Fe│Feb 19 22:36:47 leinen hass[7039]: File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__ │
Fe│Feb 19 22:36:47 leinen hass[7039]: yield self # This tells Task to wait for completion. │
Fe│Feb 19 22:36:47 leinen hass[7039]: File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup │
Fe│Feb 19 22:36:47 leinen hass[7039]: future.result() │
00│Feb 19 22:36:47 leinen hass[7039]: File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result │52
20│Feb 19 22:36:47 leinen hass[7039]: raise self._exception │
ta│Feb 19 22:36:47 leinen hass[7039]: File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run │
--│Feb 19 22:36:47 leinen hass[7039]: result = self.fn(*self.args, **self.kwargs) │--
20│Feb 19 22:36:47 leinen hass[7039]: File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/netatmo.py", line 53, in setup │
20│Feb 19 22:36:47 leinen hass[7039]: 'read_station read_camera access_camera ' │
20│Feb 19 22:36:47 leinen hass[7039]: File "/srv/homeassistant/lib/python3.5/site-packages/pyatmo.py", line 74, in __init__ │
20│Feb 19 22:36:47 leinen hass[7039]: self._accessToken = resp['access_token'] │
20│Feb 19 22:36:47 leinen hass[7039]: TypeError: 'NoneType' object is not subscriptable#033[0m
When activating it again, I get… simply nothing in my logfiles (neither with homeassistant.components.netatmo: debug). But I realized that it seems to try read_station, read_camera and access_camera – I miss read_homecoach? Was it ever intended to work with Home Coach devices?
Any help would be appreciated as I am not a developer. If you need further information just ask. I’m running HA 0.87.1 on Hassbian.
Cheers,
Marianne
The user in another posting is affected too. I’m not allowed to post so many links
First: You need to put the password between “” else you got an error, but after i tried it with my password as “password” within Quotes i got invalid config.
