Since I upgraded my Netatmo devices (weather and camera) are not working anymore. The HA cloud entry in integrations shows an error. I think I saw an email from Netatmo that they are changing something in auth, but not sure this is related. Below the error in logs:
Logger: homeassistant.config_entries
Source: components/netatmo/data_handler.py:164
First occurred: 09:47:32 (1 occurrences)
Last logged: 09:47:32
Error setting up entry Home Assistant Cloud for netatmo
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 986, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore[return-value] # noqa
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1064, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1049, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 960, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 500, in sock_connect
return await fut
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 535, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('169.254.41.3', 80)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 357, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 153, in async_setup_entry
await data_handler.async_setup()
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 108, in async_setup
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 204, in subscribe
await self.async_fetch_data(signal_name)
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 164, in async_fetch_data
await self.data[signal_name].async_update()
File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 649, in async_update
await self._async_update_all_camera_urls()
File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 659, in _async_update_all_camera_urls
await self.async_update_camera_urls(camera_id)
File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 724, in async_update_camera_urls
] = await self._async_check_url(
File "/usr/local/lib/python3.10/site-packages/pyatmo/camera.py", line 731, in _async_check_url
resp = await self.auth.async_post_request(url=f"{url}/command/ping")
File "/usr/local/lib/python3.10/site-packages/pyatmo/auth.py", line 335, in async_post_request
async with self.websession.post(
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 1138, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 535, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1206, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1175, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 992, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 169.254.41.3:80 ssl:default [Connect call failed ('169.254.41.3', 80)]
