So yeah, try the new API I guess, only specifying the client_id and client_secret? It looks like itâs only for HA version 0.105 though, so not 100% sure.
âIf you have an existing configuration, you will need to remove/update that and run the configuration flow dialogue to get their sensors/etc, back using the configuration.yaml option.â
I updated my configuration. I have no idea what ârun the configuration flow dialogueâ means. Thereâs no integration to see, anymore.
I was figure it out
You need to go to Settings -> Integration -> Click on +
And then manually add Netatmo, which redirect you to netatmo pages, where only confirm authorization tokenâŚ
And thats all
Update HA, leaving the old Netatmo config. HA updated, but failed on Netatmo (I expected this).
Tried to add the integration like others and I also got âI Acceptâ loop.
Put in the correct details in configuration.yaml (just client_id and client_secret and rebooted HA
HA came up with no errors, I went to the Configuration/Integrations to add Netatmo - it prompted me for either using configuration.yaml or cloud - I chose configuration.yaml.
Got redirected, but this time no âI Acceptâ loop (though strangely the Netatmo webpage went blank).
Went back to my HA web page tab and Netatmo was there - all the the same entity_id too.
Had done the same as @markbajaj arkbajaj but did get after a reboot the message client_id was not recognized, in htop i did notice home assistant was still working on some updates, waited for like 30min and restarted again (with the c lient_id and client_secret in the config yaml) and then the integration noted me there is a configuration.yaml and this did continue.
