After upgrading from 0.93.2 to 0.94 (I am now using 0.94.4), my Netatmo integration fails.
I do own both weather station (indoor and outside modules) and thermostat plus valves.
Using the new Homekit integration for the thermostat and the valves I managed to have these working again but I consider this as a workaround only as the Netatmo integration should still work. Sadly, I have no solution for the Netatmo weather station
Here is the log of the error (I tried to reset my codes but it changed nothing) :
Error during setup of component netatmo
File "/usr/src/homeassistant/homeassistant/setup.py", line 156, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 91, in setup
'read_station read_camera access_camera '
File "/usr/local/lib/python3.7/site-packages/pyatmo.py", line 85, in __init__
self._accessToken = resp["access_token"]
TypeError: 'NoneType' object is not subscriptable
Does anyone encounter the same difficulties ?
Thank-you.
