Hi, I’ve been using Netatmo integration to control my Netatmo outdoor cameras, but since a couple of hours ago it suddenly stopped working.
From the integrations section, I can see that the integration failed to set up (and it stays like that even if I reload it or reboot the system).
This is what I see from the logs:
Logger: homeassistant.config_entries
Source: components/netatmo/data_handler.py:199
First occurred: 20:05:07 (3 occurrences)
Last logged: 20:06:39
Error setting up entry Netatmo videocamere for netatmo
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 164, in async_setup_entry
await data_handler.async_setup()
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 156, in async_setup
await self.async_dispatch()
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 280, in async_dispatch
await self.subscribe(HOME, signal_home, None, home_id=home.entity_id)
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 243, in subscribe
await self.async_fetch_data(signal_name)
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 199, in async_fetch_data
await getattr(self.account, self.publisher[signal_name].method)(
File "/usr/local/lib/python3.10/site-packages/pyatmo/account.py", line 78, in async_update_status
await self.homes[home_id].update(raw_data)
File "/usr/local/lib/python3.10/site-packages/pyatmo/home.py", line 132, in update
self.rooms[room["id"]].update(room)
KeyError: '0'
and this:
Source: helpers/entity_component.py:166
First occurred: 20:06:31 (14 occurrences)
Last logged: 20:06:38
Error setting up entry Netatmo videocamere for cover
Error setting up entry Netatmo videocamere for light
Error setting up entry Netatmo videocamere for select
Error setting up entry Netatmo videocamere for sensor
Error setting up entry Netatmo videocamere for switch
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 409, in async_setup_entry
return await component.async_setup_entry(entry)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 166, in async_setup_entry
raise ValueError("Config entry has already been setup!")
ValueError: Config entry has already been setup!
I didn’t change anything and I’ve also tried to restore a backup where I’m 100% sure everything worked properly, but nothing changed.
Does anybody know what’s going on?
