I’m receiving this error when trying to adjust the temperature of my netatmo devices through HA.
I have already tried to remove the integration, readd, restart my HA,…
[140020887911152] 500 - Internal Server Error - device.setThermPoint is not a function (11) when accessing 'https://api.netatmo.com/api/setroomthermpoint'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 141, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1488, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1523, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 642, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 681, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 679, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 544, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 404, in async_set_temperature
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/netatmo/climate.py", line 416, in set_temperature
self._home_status.set_room_thermpoint(self._id, STATE_NETATMO_MANUAL, temp)
File "/usr/local/lib/python3.8/site-packages/pyatmo/thermostat.py", line 240, in set_room_thermpoint
return self.auth.post_request(url=_SETROOMTHERMPOINT_REQ, params=post_params)
File "/usr/local/lib/python3.8/site-packages/pyatmo/auth.py", line 171, in post_request
raise ApiError(
pyatmo.exceptions.ApiError: 500 - Internal Server Error - device.setThermPoint is not a function (11) when accessing 'https://api.netatmo.com/api/setroomthermpoint'
So if I have netatmo modulate thermostat I won’t be able to control the valves right? Is that why I’m having the device.setthermpoint is not a function error
Any news on this? I tried the integration again and still not working. BUT I’m reading all the data just fine, and even the battery level.
Still can’t set temperatures cause of error "device.setThermPoint is not a function "
Work on using the new API is still ongoing as it involves a major upgrade of the underlying library. About the issue mentioned initially, I don’t know whether this is still valid.
I still get the “Server Error - device.setThermPoint is not a function” error when trying to set the temperature on my Thermostat or valves. (I’m on HA 2021.12.10)
Yes, its a modulating one… switched from the “normal” Netatmo smart thermostat to the modulating recently. Is anyone working on getting the modulating working? I’m happily willing to test or to provide access to mine for testing.
So, since winter is coming, any news on this? With current Gas prices in Europe I would love to have more control over my Modulating Netatmo thermostats. @cgtobi
