I have some issues with my Netatmo integration, without changing anything to its configuration.
The log reads:
Logger: homeassistant.config_entries
Source: components/cloud/account_link.py:146
First occurred: 17:48:05 (1 occurrences)
Last logged: 17:48:05
Error unloading entry Home Assistant Cloud for netatmo
File "/usr/local/lib/python3.8/site-packages/pyatmo/auth.py", line 144, in query
rsp = self._oauth.post(url=url, data=params, timeout=timeout)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 578, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests_oauthlib/oauth2_session.py", line 477, in request
url, headers, data = self._client.add_token(
File "/usr/local/lib/python3.8/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 198, in add_token
raise TokenExpiredError()
oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 316, in async_unload
result = await component.async_unload_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 177, in async_unload_entry
await hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/pyatmo/auth.py", line 224, in dropwebhook
resp = self.post_request(WEBHOOK_URL_DROP, post_params)
File "/usr/local/lib/python3.8/site-packages/pyatmo/auth.py", line 159, in post_request
resp = query(url, params, timeout, 3)
File "/usr/local/lib/python3.8/site-packages/pyatmo/auth.py", line 153, in query
self._oauth.token = self.refresh_tokens()
File "/usr/src/homeassistant/homeassistant/components/netatmo/api.py", line 33, in refresh_tokens
run_coroutine_threadsafe(
File "/usr/local/lib/python3.8/concurrent/futures/_base.py", line 439, in result
return self.__get_result()
File "/usr/local/lib/python3.8/concurrent/futures/_base.py", line 388, in __get_result
raise self._exception
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 444, in async_ensure_token_valid
new_token = await self.implementation.async_refresh_token(self.token)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 81, in async_refresh_token
new_token = await self._async_refresh_token(token)
File "/usr/src/homeassistant/homeassistant/components/cloud/account_link.py", line 146, in _async_refresh_token
return await account_link.async_fetch_access_token(
File "/usr/local/lib/python3.8/site-packages/hass_nabucasa/account_link.py", line 112, in async_fetch_access_token
resp.raise_for_status()
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_reqrep.py", line 941, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request', url=URL('https://account-link.nabucasa.com/refresh_token/netatmo')
I don’t think my token really has expired. I have created it just a few days ago and it worked fine for the last couple of days.
