Netatmo not being initialized
Hi
I am trying to connect a Netatmo Security Indoor camera to Home Assistant. I have configured the configuration file as explained in the Home Assistant for Netatmo
when starting the server is shows on the terminal the following messages
INFO:homeassistant.util.package:Attempting install of https://github.com/jabesq/netatmo-api-python/archive/v0.9.2.zip#lnetatmo==0.9.2
ERROR:homeassistant.util.package:Unable to install package https://github.com/jabesq/netatmo-api-python/archive/v0.9.2.zip#lnetatmo==0.9.2: Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-9w14t5ym-build/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(’\r\n’, ‘\n’), file, ‘exec’))” install --record /tmp/pip-l2yw22wu-record/install-record.txt --single-version-externally-managed --compile --user --prefix= --home=/tmp/tmpsx9ouna9” failed with error code 1 in /tmp/pip-9w14t5ym-build/
Could you please indicate me which could be the problem?
Thanx
