hi,
my netatmo presence camera integation stopped working some days ago.
i tried :
- removing client_id and client_secret
- generating a new api key in dev.netatmo.com
- reboot ha
- add the new client_id and client_secret in configuration.yaml
homeassistant:
external_url : "https://myhassio-from-outside.com"
netatmo:
client_id: 5f90xxx53b
client_secret: nXxxxsIF
- reboot ha
- added netatmo integration
but no camera detected :
and i get this error in log
Logger: homeassistant.components.camera
Source: components/netatmo/data_handler.py:117
Integration: Camera (documentation, issues)
First occurred: 9:27:31 PM (1 occurrences)
Last logged: 9:27:31 PM
Error while setting up netatmo platform for camera
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 193, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/netatmo/camera.py", line 94, in async_setup_entry
async_add_entities(await get_entities(), True)
File "/usr/src/homeassistant/homeassistant/components/netatmo/camera.py", line 53, in get_entities
await data_handler.register_data_class(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 149, in register_data_class
await self.async_fetch_data(
File "/usr/src/homeassistant/homeassistant/components/netatmo/data_handler.py", line 117, in async_fetch_data
self.data[data_class_entry] = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 122, in __init__
self.update_camera_urls(camera_id)
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 179, in update_camera_urls
self.cameras[home_id][camera_id]["local_url"] = check_url(
File "/usr/local/lib/python3.8/site-packages/pyatmo/camera.py", line 167, in check_url
resp = self.auth.post_request(url=f"{url}/command/ping")
File "/usr/local/lib/python3.8/site-packages/pyatmo/auth.py", line 170, in post_request
f"{resp.status_code} - "
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 898, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.8/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
What can i do more to get my camera on again ?
thanks for your feedback
