I set up cloud link, paid for a Nebu Casa subscription. Tried all combinations of removing all Netatmo config and keeping them, recreating the integration each time, restarting HA each time. Integration says it’s connected, authenticated from Netatmo popup. Still nothing, and same error in logs. Netatmo integration card shows blank for devices and entities. What am I doing wrong?
Thank you for your speedy replies, this is the only error I find when searching for Netatmo (there used to be more regarding webhooks, but now that I’m connected to the Home Assistant Cloud those are gone)
2020-10-09 12:04:49 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up netatmo platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 193, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py", line 159, in async_setup_entry
async_add_entities(await find_entities(data_class_name), True)
File "/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py", line 150, in find_entities
NetatmoSensor(data_handler, data_class_name, module, condition)
File "/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py", line 247, in __init__
self._device_name = module_info["station_name"]
KeyError: 'station_name'
Sorry to board this thread. I am not sure if my problem deservses its own.
I am all new to home assistant and have just setup hass.io on a raspberry pi this week. I have not started with any fancy stuff and wanted in a first step to add all my devices into home assistant. One of them being the Netatmo Presence Outdoor Camera. For this I have now done the following:
To enable remote control:
Creating a DuckDNS account
Installing the DuckDNS Add-On via the HA UI
Installing the NGINX Add-On via the HA UI
Entered my DuckDNS URL in the general configuration via the HA UI
Forwarded the external port 443 to the internal port 443 of my home assistant on the router
Forwarded also port 80, but as far as I am aware NGINX will reroute this to 443 internally.
The Port Forwarding seems to be working as I can access the home assistant via the DuckDNS URL.
To setup Netamo:
I created a Development App on the Netatmo webpage.
Added the credentials to the configuration.yaml manually using the file editor.
added the Netatmo Integration via the HA UI using configuration.yaml as settings.
The setup found my camera and I have access to the video feed. However I don’t seem to get the netatmo_movements events. They are not even listed in the Developer Tools Event list.
How can I check where the integration may hang? I have already turned on debug logging for the Netatmo component. It seems to find the webhook, but is having some issue to setup light.netatmo, which I assume is necessary to control the light on the Presence camera.
2020-10-10 07:54:35 INFO (MainThread) [homeassistant.components.light] Setting up light.netatmo
2020-10-10 07:54:35 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 30 seconds.
I would like to use the detections of the camera within home assistant.
Any help is much appreciated. And sorry for any inconvinience as I am still unexpierienced with home assistant, yaml and python.
File “/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py”, line 120, in find_entities
for module_id in data_class.get_modules(station_id):
File “/usr/local/lib/python3.8/site-packages/pyatmo/weather_station.py”, line 88, in get_modules
“station_name”: station[“station_name”],
KeyError: ‘station_name’
I assume you’re webhook is not setup correctly. Please check the dev portal if it is banned. Also check if your internal and external URLs are set correctly.
@cgtobi thank you for your reply and the support you are giving. It is much appreciated. You are right, when I set it up it was not yet visible, but in the meantime the webhook got banned. Now I need to figure out what led to the banning. I have now unbanned the connection.
On the Home Assistant side, I tried to unregister the webhook, cleared my log file, restarted the Home Assistant and registered the webhook using the developer tools.
The following was logged:
2020-10-11 08:28:17 INFO (MainThread) [homeassistant.components.netatmo] Register Netatmo webhook: https://www.myaddress.duckdns.org/api/webhook/SomeLongHexValue
2020-10-11 08:28:17 INFO (MainThread) [homeassistant.components.light] Setting up light.netatmo
2020-10-11 08:28:17 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 30 seconds.
2020-10-11 08:28:28 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2947961904] Handler is already defined!
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 138, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1335, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1370, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 148, in register_webhook
webhook_register(
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 36, in async_register
raise ValueError("Handler is already defined!")
ValueError: Handler is already defined!
I have masked my duckdns address, which in reality matches the ones in the system settings and the long string after /webhook/ assuming this will lead to my netatmo account.
This is my URL setup. Next to the .org I have not identified an additional port.
I’m getting the same type of error using 0.116.2, I am using the :
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 193, in _async_setup_platform
File “/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py”, line 160, in async_setup_entry
File “/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py”, line 151, in find_entities
File “/usr/src/homeassistant/homeassistant/components/netatmo/sensor.py”, line 248, in init
self._device_name = module_info[“station_name”]
