Apparently there are issues with some parts of the Netatmo backend. This has nothing to do with the integration. You just need to be patient until Netatmo has fixed the issue.
Same⊠both rain n temp unit doesnt respond to HA. but works fine through netatmo app.
Datas reappeared themselves 1h ago for me, it just needs to be patient !
hopefully. so far it just states NaN atm. webhook is not banned what it seems. hopefully soon back online. went offline last night.
I noticed mine were back this morning.
Not for me.
Well, the Netatmo status page gives you a hint why that is.
Sure does, although I was encouraged by the report from @drjjr. Funny thing is that everything has worked in the Netatmo app all along. They have had numerous outages over the past year. Iâm probably not going to buy into their ecosystem anymore.
Yes, they are not making a particular good impression recently. Unfortunately.
Since Upgrading ti 0.118 I have an issue with my Netamo Pressence and the Stream Record.
Does anybody know why?
I know what the problem is, but I havenât had time to fix it.
Thx! Let us know when a fix is out
Hello.
I just tried to add Netatmo integration for setting up a netatmo thermostat and when the integration redirect me to the authentication page of netatmo it shows the following error:
âArray is not an allowed scope for Home Assistant cloudâ.
What should I do?
If you have a GitHub account open an issue about it and tag me.
did you find a solution. I am using netatmo presence with Nabucasa but getting the same error. No motion sensors and no light switch. Video is available. Webhook is ok (green checkmark status on netatmo developer site).
Best M
Hello
iâm aa newbee and
I also have problems with netatmo webhook integration.
my config on raspberry pi4-8go is as follows:
Version | core-2021.2.1 |
Type dâinstallation | Home Assistant OS |
DĂ©veloppement | false |
Superviseur | true |
Docker | true |
Environnement virtuel | false |
Version de Python | 3.8.7 |
Famille du systĂšme dâexploitation | Linux |
Version du systĂšme dâexploitation | 5.4.79-v8 |
Architecture du processeur | aarch64 |
Fuseau horaire | Europe/Paris |
Host Operating System | Home Assistant OS 5.10 |
Mise Ă jour | stable |
Version du supervisor | supervisor-2021.02.5 |
Version de Docker | 19.03.13 |
Taille total du disque | 13.9 GB |
Taille du disque utilisé | 2.2 GB |
Sain | true |
Prise en charge | true |
Tableau de bord | rpi4-64 |
API du superviseur | ok |
Version API | ok |
Add-ons installés | Duck DNS (1.12.4), File editor (5.2.0) |
i have the following logs in home assistant:
2021-02-09 09:19:04 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 30 seconds.
2021-02-09 09:19:34 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 60 seconds.
2021-02-09 09:20:34 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 90 seconds.
2021-02-09 09:22:04 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 120 seconds.
2021-02-09 09:24:04 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 150 seconds.
2021-02-09 09:26:34 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 180 seconds.
2021-02-09 09:29:34 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 180 seconds.
2021-02-09 09:32:34 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 180 seconds.
2021-02-09 09:35:34 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 180 seconds.
2021-02-09 09:38:34 WARNING (MainThread) [homeassistant.components.light] Platform netatmo not ready yet. Retrying in 180 seconds.
after a few minutes I am banned from the netatmo webhook.
so i canât integrate automations.
I specify that I have the return of my cameras on the dashboard, this works correctly.
thanks for help and sorry for my bad english.
hello,
i have an error with netatmo stream, do you have an idea for resolve this ? (stream is ok with an other camera)
2021-02-09 12:26:22 INFO (MainThread) [homeassistant.components.stream] Started stream: http://XXXXX//live/files/high/index.m3u8
2021-02-09 12:26:24 ERROR (stream_worker) [libav.mp4] Malformed AAC bitstream detected: use the audio bitstream filter 'aac_adtstoasc' to fix it ('-bsf:a aac_adtstoasc' option with ffmpeg)
2021-02-09 12:26:24 ERROR (stream_worker) [homeassistant.components.stream.worker] Stream connection failed: http://XXXX//live/files/high/index.m3u8
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/stream/worker.py", line 56, in stream_worker
_stream_worker_internal(hass, stream, quit_event)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/stream/worker.py", line 293, in _stream_worker_internal
mux_video_packet(packet) # mutates packet timestamps
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/stream/worker.py", line 213, in mux_video_packet
buffer.output.mux(packet)
File "av/container/output.pyx", line 204, in av.container.output.OutputContainer.mux
File "av/container/output.pyx", line 227, in av.container.output.OutputContainer.mux_one
File "av/container/core.pyx", line 257, in av.container.core.Container.err_check
File "av/error.pyx", line 336, in av.error.err_check
av.error.PermissionError: [Errno 1] Operation not permitted: '<none>'; last error log: [mp4] Malformed AAC bitstream detected: use the audio bitstream filter 'aac_adtstoasc' to fix it ('-bsf:a aac_adtstoasc' option with ffmpeg)
Nobody for help me please, always the same issueâŠ
Impatience is not a virtue. You posted in a random âNetatmo problemâ thread that might have nothing to do with your issue.
But anyways, is your instance exposed to the WAN on port 443 (and reachable)?
