Netatmo problems
Hi all,
Two problems here:
Home assistant don’t find noise.
I need to create 3 sensors for each one:
Module
Station
Raing Gauge
If i use:
platform: netatmo
station: netatmo
modules:
Inside:
- temperature
- humidity
- noise
- pressure
- co2
- wifi_status
Outside:
- temperature
- humidity
- battery_vp
- min_temp
- max_temp
RainGauge:
- rain
- sum_rain_1
- sum_rain_24
- battery_vp
- rf_status
WindGauge:
- WindAngle
- WindStrength
- GustAngle
- GustStrength
- rf_status
in one sensor the home assistant only recognize the first module.
Anyone knows the cause of this two problems?
Have this errors too:
16-09-06 14:57:08 homeassistant.components.camera: Error while setting up platform netatmo
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 98, in _setup_platform
    discovery_info)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/camera/netatmo.py", line 41, in setup_platform
    for camera_name in data.get_camera_names():
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/camera/netatmo.py", line 99, in get_camera_names
    self.update()
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/util/__init__.py", line 296, in wrapper
    result = method(*args, **kwargs)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/camera/netatmo.py", line 113, in update
    self.welcomedata = lnetatmo.WelcomeData(self.auth)
  File "/home/hass/.homeassistant/deps/lnetatmo.py", line 304, in __init__
    self.default_home = list(self.homes.values())[0]['name']
IndexError: list index out of range
Here’s my Netatmo configuration if that can help you (all measurements work fine):
  platform: netatmo
  modules:
    Indoors:
      - temperature
      - max_temp
      - min_temp
      - humidity
      - noise
      - pressure
      - co2
    Outdoors:
      - temperature
      - max_temp
      - min_temp
      - humidity
    Kids bedroom:
      - temperature
      - max_temp
      - min_temp
      - humidity
      - co2
For the second issue, there’s a bug in the Netatmo Python library Home Assistant is using but it still works.
Ok so the errors is normal.
The noise works in your config?
Yes it does.
I try again and now everything works flawless.
:slight_smile: Thanks for help.
Thanks I had the same issue :slight_smile:
One other thing - how do you get your ‘rooms’? All i get is icons across the top?
Sorry for the noob question, i’ve searched and can’t find
Scrap that :slight_smile: sussed it in the groups/rooms. Those yaml files are so fussy though :wink:
How you get the above view?
Mine is like this (inside circle 18.8C):
sorry newb here
Do you have netatmo or other weather hub?
Netatmo. In configurator I have just this for “climate:”
climate:
  - platform: netatmo
When i back home I will post here my conf.
Do you have rain gauge or wind too?
Thanks!
Nope too expensive, awaiting their price to go below 35 Euro each :stuck_out_tongue:
Hi All ,
I have two thermostat of Netatmo one for poele and one for central heating
i put the config in configuration.yaml
climate:
  - platform: netatmo
    thermostat_name : poele
  - platform: netatmo
    thermostat_name : centrale
i have two problem
First : the temperature on poele is not good
Second : i have twice information on interface
Do you have an idea on my problem pls ?
Thanks by advance
Have a nice day
:slight_smile:
The component work only for one thermostat not multiple
Thanks for your answer
oh ok !!
And how make when we are two thermostat ?
hey skinnedpt :slight_smile:
You never shared your config for the view. Can you do it ? Would be great :wink:
i am just to change to Home assitant , i was on jeedom but some issues on it and not solved
I decided to go on HA
I am trying to contact @gieljnssns
Thansk for yoru answer
Have a nice day
Hi everyone,
I’m considering to buy a netatmo thermostat for my boiler, but I want to do more than just watch the thermostat temperarure.
Is it possible to perform some actions like “turn heat on/off”, “check if heat is on”, etc.?
Which services are available for this thermostat?
Thanks,
nelse
