Hey guys,
i got some netatmo radiator valves and played around a bit. I set up an automation which turns off the valve or better the valve will be turned into frost guard mode (7 degree) when a window in the same room is open.
When the window is shut again the valve will go to the same schedule it was before. This is a part from my automation.
alias: Fenster - Heizung
description: ''
- platform: state
entity_id: binary_sensor.fenstersensor_schlafzimmer
to: 'on'
- platform: state
to: 'off'
condition: []
- choose:
- conditions:
- condition: template
value_template: '{{ trigger.id == ''offonschlaf'' }}'
sequence:
- service: climate.turn_off
entity_id: climate.netatmo_schlafzimmer
- conditions:
value_template: '{{ trigger.id == ''onoffschlaf'' }}'
sequence:
- service: climate.turn_on
default: []
mode: single
The automation works but when a window is open between two schedule mode (for example night and morning scene in the netatmo app) the new temperature will overwrite the automation and eventually the valve will start heating even if the window is open.
What is the best way to prevent this? I absolutely have no idea how to start here.
