Hi, I’m using the Netatmo integration with my own client ID from Netatmo now. Otherwise, I was not able to connect to the cameras. Only my weather station and its sensors showed up in HA.
Along with the switch came another issue: Now I’m not able to use the sensors as triggers or conditions in automations. The rules are executed whatever temperature, humidity etc. I chose as settings. On my dashboards they seam perfectly connected, showing their current status and data. But in automations they don’t work. According to the trace display, their nodes are simply not executed.
Before I switched to the new configuration everything worked fine over the HA Cloud. Do I miss a thing? Every kind of help to get things up and working again would be very much appreciated.
