Hi all,
Does anyone know if the Netatmo Indoor Sirene is fully functional with Home Assistant?
Hi all,
If you have one we can get it going.
I will let you know when it arrives :).
I have one now, can I help in the development?
If you don’t mind get in contact with me on discord.
any progress so far ? I also got a siren from netatmo and would love integration!
thanks in advance,
Not explicitly, but it probably sends out webhook events. If we can gather those it can be implemented/exposed.
If you tell me how to check / help i can retrieve needed data for you
Thanks in advance,
note : the siren is connected using BLE to the camera, the siren itself is NOT connected to wifi.
So if there are any hooks, they should come from the camera :
Wireless connection with the Smart Indoor Camera via Bluetooth Low Energy (BLE)
https://pro.netatmo.com/eu/siren/specifications
If you’re on a recent version go to the developers section and events. There you can listen for netatmo_event
(at the bottom of the page). It will print all event below.
Ok,
then i understand i must be in “listen” mode while at the same time, triggering alarm or launching deterrent sound from the application (dog, baby cries, hover, etc…);
will be able to test when i’m alone in the house tomorrow, i’ll keep you posted.
So, i did it, and i triggered the alarm from the app itself. no event at all.
As it is a BLE connection between the camera and the siren, i’m unsure if we will be able to do anything with it …
That’s a shame, as i have aqara door and vibrations sensors, i wanted to be able to trigger the alarm if one of the sensors detects something …
any advice ?
Did you make sure that you’re receiving any webhook events at all?
Haha, I figured that two days ago, i was not receiving the webhooks but i have cleared this issue now.
I will retest this afternoon and keep you posted
So i did retest, and yes, there are some webhooks
"event_type": "netatmo_event",
"data": {
"type": "siren_sounding",
"data": {
"user_id": "**REMOVED_HEXADECIMAL**",
"event_type": "siren_sounding",
"device_id": "**REMOVED_MACADDRESS**",
"home_id": "**REMOVED_Home_HEXADECIMAL**",
"home_name": "Maison",
"camera_id": "**REMOVED_MACADDRESS**(same as previous one)",
"event_id": "**REMOVED_EventID_HEXADECIMAL**",
"module_id": "**REMOVED_MACADDRESS**(Not the same - maybe bluetooth siren)",
"sub_type": 2,
"push_type": "NACamera-siren_sounding"
"origin": "LOCAL",
"time_fired": "2020-08-18T09:01:57.990307+00:00",
"context": {
"id": "**REMOVED_HEXADECIMAL**",
"parent_id": null,
"user_id": null
Also, note that it is possible to send commands to the siren from the Netatmo app (like dogs barking, baby crying, home sounds (like hoover etc), but when i do this, no netatmo_event are triggered.
I wonder if there is a possibility to send a command like a “set_siren_sound” the same as “set_person_away” listed here : https://www.home-assistant.io/integrations/netatmo/#set-person-away
hi @cgtobi
Anything more needed to integrate the netatmo siren ?
off topic :
moreover, i know how webhooks working, however, i now need to automate some “presence graphs” as well as nodered flows…
any tips on how to do that as this is not a “sensor” ? how can i get the state from the webhook ?
I have seen this : is it the correct way forward : Netatmo in HA 0.105
Sorry, I haven’t had time yet. I’ll put it on my list. But triggering the siren without a documented API is a lot of guess work.
I have no idea about node red, sorry. You gotta use events. Check out the Netatmo webhook based event cookbook.
hello
i have two netatmo indoor siren with two welcome cams.
did someone manage to pilot the netatmo indoor siren with the webhook informations ?
i’m looking for this but i have difficulties to integrate that in home assistant.
thanks.
Any updates?
