I recently have a Netatmo Smart Modulate Thermostat installed. It’s an new version of the normal Smart Thermostat that supports OpenTherm.
It seems that the current Netatmo integration doesn’t support this new version. No idea if it’s because it’s not in the API yet. Any idea?
cgtobi
(Tobi)
February 1, 2021, 9:21am
2
I haven’t heard of any issues with it so far. Can you please run the self test script and contact me via PM or Discord to discuss the results?
mcon
(Matt)
March 10, 2022, 10:08am
3
I’m looking at buying the netatmo opentherm stat - did you get it working please?
cgtobi
(Tobi)
March 10, 2022, 2:22pm
4
This is implemented and working but not released yet.
mcon
(Matt)
March 11, 2022, 3:27pm
5
Ah ok brill thanks. Any idea when it might make the release?
ktvanzwol
(ktvanzwol)
May 13, 2022, 11:35am
7
Did the support made it into 2022.5?
The thermostat device shows up in 2022.5.4 but I only get a select entity for the schedule, not a climate entity for controlling the thermostat. Is this lack of support for the modulate thermostat or something else?
Karsten
cgtobi
(Tobi)
May 16, 2022, 5:36am
8
No, sorry, support for modulating thermostats has not been submitted.
Ok, Thanks for the update, any idea when it will make it in?
Karsten
Any news on which version it will be introduced? I really want to add my OpenTherm Netatmo.
cgtobi
(Tobi)
June 4, 2022, 6:38am
11
It is implemented and working. The upstream changes are currently being reviewed.
Please understand that I won’t give an ETA.
OK! Thank you for the info. I will be patiently waiting for it.
gaetanb49
(GaetanB49)
September 29, 2022, 12:24pm
13
I have a Netatmo Smart Modulate Thermostat and I only have a select entity.
is there or will there be a solution soon?
cgtobi
(Tobi)
September 30, 2022, 5:24am
14
This will be supported in the next version (2022.10), currently this is only available in the beta.
JeromeS68
(Jerome S68)
October 3, 2022, 6:39pm
15
I tried the beta version.
Seems to work fine, only bug I found : it’s not possible to switch to away mode.
I get this error :
‘pyatmo.exceptions.ApiError: 400 - Bad request - In room 1475964401, property /therm_setpoint_mode: should be equal to one of the allowed values (21) when accessing ‘https://api.netatmo.com/api/setstate ’’
Hope it can help.
cgtobi
(Tobi)
October 3, 2022, 8:36pm
16
Thanks for reporting. I need to take a look.
