Ok, so maybe the reason I have never seen any such smoke detector events is simply because the detector hasnāt sent any yet? (it only sends events in case of a fire/smoke detection?)
Of so, is it possible to make it send test events?
I donāt own one of those but according to the documentation there is an event called sound_test for sound test. But I canāt tell how to trigger that.
That sounds like just pressing the sound test button on the unit itself ? I assume there is such a button. When I get back home later this week, Iāll test that and report back.
Hi all,
is there any progess on this? Was anyone able to receive any event, e.g. sound test, from the smoke alarm? In the HA wiki the smoke alarm isnāt mentioned at all.
Hi Viking,
I recently purchased a Netatmo smoke alarm. Got it installed and setup via the Netatmo App.
I used the native HA Netatmo integration and Nabu Casa as well - but I only get 1 device and 1 entity in HA - thats āMy Homeā. No Smoke Alarm device or entity, hence no sensor.
I can see and test the smoke alarm via the Netatmo app as I should - its just, that it does not show in HA.
I was wondering, that since you got an event in HA - you must have the smoke alarm integrated.
Any chance you can guide me to uderstand what Iām missing/do not understand about the integration?
Thanks in advance
At the moment Netatmo smoke alarms are only supported via webhook events. Those can be used in HA. Beyond that there is no real API to be used. This is why there is no device in HA.
Exactly, but webhook is ok (if you can get it working). It took me a long time to solve the certificate issues I had, but eventually I came through, and now itās working OK. @cgtobi provided valuable assistance in my webhoook quest.
Hi Tobi, IĀ“m new to the forum as well as Home Assistant. Just installed the system and have onboarded my devices, but can not find my 3 smoke alarms from Netatmo. Tried to read up on the forums here and found this thread. I also found some other threads indicating that the device should be detected at least using the homekit integration, but that does not seem to be the case. Has there been any progress on the integration or is webhooks the only option still?
Thanks for the suggestion, any pointers on how to set up ESPHome? The project pages on .io are unavailible and the integration in HA just asks for a host and a port, is ESPHome something I need to run on another system?
Nope, currently struggling to get the bluetooth integration to work, do not get any identified devices, just the temp mac:s of multiple devices, not sure how this is supposed to work, but will start by fixing this.
