Hi!
I recently purchased 3 netatmo smoke alarms with the intention of configuring them as HomeKit devices. Only after I installed them I realized they need to be linked using Bluetooth, which, if I understand correctly, home assistant doesn’t support (yet). No worries, as there is an official integration I can use that until the day comes that I can use HomeKit and use my smoke alarms completely locally.
Problem is, when i set up the integration, my 3 alarms don’t get added to it. Granted, I can’t set up the webhook functionality because I can’t get my home assistant to be available on port 443, but do I need it to be able to get sensor data? Or is there no sensor data for the smoke alarm, only events? In the netatmo api it does look like there is some data available though…
Thanks so much for your help and advice!
