Hi there
Simple question, does anybody using a Netatmo thermostat can handle it?
I’ve searched for like 3 days of a simple way to use it (we’ve got a pellet stove) in HASSio, but that’s a real pain…
I’ve used the generic climate with my broadlink plugs connected to my electrical heaters since a year, using automations when we’re home/at work/during sleep time to switch the heaters from heat to away mode.
There is no way I can find to reproduce this behavior with the climate.netatmo module…
You can, from what I’ve seen, only choose from 4 presets, I even haven’t find a way to change the presets temperatures, the “boost” mode for example is at 25.5°C (77°F).
I’ve tried to switch from “off” to “schedule” with a schedule all day long in the netatmo app but it doesn’t seems to do anything.
So now I’m just using it “always on” on manual and just changing the temperature in my automation… But doesn’t seems to me the best way to use it…?
HASSIO v0.100.3
