Since few days the Netatmo component is not working anymore. I am not sure if its a 0.50.2 problem or general.
Hi Claudio,
can you eleborate?
I am trying to setup HomeAssistant with my Netatmo stuff and have two thermostats with two relays for different rooms (zones)
what i found till now it takes only the information of one. It shows two but uses one. (the first it seems)
yes its a known bug. The developer did not fix it.
Use this fix. It will show both thermostat with correct values, but you will not be able to changevalues from HASS
I like to report this fixed for a long time now
