I need some help since I couldn’t find the info I’m looking for on the forum.
I want to buy a thermostat for my boiler, in order to have it integrated with my current HA setup.
The only two compatible brands I found are Netatmo and MiGo, but I think that Netatmo is the only pne that can integrate with HA, right?
The thing is I want to do more than just watch the thermostat temperarure.
Is it possible to perform some actions like “turn heat on/off”, “check if heat is on”, etc.?
Which services are available for the netatmo thermostat?
Hi, here is what Netatmo thermostat looks in HA. Yes you can change target temperature, turn on/off Away mode and also see when boiler was turned on and off. I am very satisfied with Netatmo and its integration into HA.
