I’m new with Hassio and Raspberry
I’m tryng to configure my netatmo thermostat.
I’ve insert in the configuration.yaml:
sensor netatmo :
- platform: netatmo
station: Casa_Caidate
netatmo:
api_key: xxxxxx
secret_key: xxxxxxx
username: xxxxxx
password: xxxxxxx
climate:
- platform: netatmo
relay: relay
thermostat: thermostat
but nothing appear in the the panoramics menu’.
In the home-assistant.log there is the follow log:
2019-04-09 17:13:57 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 416, in wait_for
return fut.result()
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py”, line 96, in setup_platform
for room_id in room_data.get_room_ids():
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py”, line 344, in get_room_ids
if not self.setup():
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/climate.py”, line 355, in setup
self.homestatus = pyatmo.HomeStatus(self.auth, home=self.home)
File “/usr/local/lib/python3.7/site-packages/smart_home/Thermostat.py”, line 130, in init
raise NoDevice(“No device found, errors in response”)
smart_home.NoDevice: No device found, errors in response
2019-04-09 18:13:52 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
Any suggestion where could be the error?
Thank in advance
Fabrizio
