I keep getting this error message, and I haven’t done anything to change it.
The API key and such are listed in the Devices above, as they have been for ages, what is the required key not provided?
Thanks!
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 107). Please check the docs at https://home-assistant.io/components/sensor/
- platform: netatmo
station: XXX
modules:
XXX:
- co2
- humidity
XXX:
- temperature
- humidity
- min_temp
- max_temp
XXX:
- sum_rain_1
- sum_rain_24
XXX:
- windstrength
- guststrength
