Hi All
First post so not sure if I’ve done it right, wasn’t sure where to post it so sorry if its in the wrong place.
New to HA but starting to get the hang of it just finished setting up my Google Nest Thermostat - gosh that took while! Anyway I’ve set up my Netatmo Weather Station and all working fine with HA the only problem is the naming of the entity I.D’s is really odd and all follow the same pattern as this example: “sensor.hall_hall_hall_living_room_temperature” now the base module is called “hall” but it beats me way its repeated this through out all the sensors. Any suggestion would be welcome and can you rename entity I.D.'s
Best Regards
Gareth
