So i just got my hands on a Netatmo weather station, set it up with one indoor and one outdoor sensor, and it all works like a charm in the netatmo app, and the weather netatmo map. I try to intergrate it into my hassio, but I keep hitting a dead end no matter what I try.
Here is what i have done.
I registered to get the Netatmo API and Secret, activated the “app” on the netatmo webpage.
Then i set up the following in my configuration.yaml.
netatmo:
api_key: yeppithsthere
secret_key: yeppithsthere
username: yeppithsthere
password: yeppithsthere
then I listed the following under my sensors:
- platform: netatmo
station: Hytta
modules:
Inne:
- temperature
- co2
- humidity
- health_idx
- min_temp
- max_temp
Ute:
- temperature
- battery_vp
- battery_percent
- humidity
- health_idx
- min_temp
- max_temp
- wifi_status
When looking at the logs after reboot this is what i get:
Error during setup of component netatmo
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 154, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/__init__.py", line 95, in setup
'read_station read_camera access_camera '
File "/usr/local/lib/python3.7/site-packages/pyatmo.py", line 85, in __init__
self._accessToken = resp["access_token"]
TypeError: 'NoneType' object is not subscriptable
and :
Tue Mar 19 2019 18:21:46 GMT+0100 (sentraleuropeisk normaltid)
Unable to set up dependencies of netatmo.sensor. Setup failed for dependencies: netatmo
Unable to prepare setup for platform netatmo.sensor: Could not set up all dependencies.
