Netatmo Wind angle split-up
The next problem. I use Netatmo sensors and I want to use the wind_angle to produce some nice pictures with a wind compass. Therefore I wanted to use the following sentences:
wind_compass:
         value_template: >-
           {% if 0.00 <= states('sensor.netatmo_wind_angle') | float <= 11.25 %}
           N
           {% elif 11.26 <= states('sensor.netatmo_wind_angle') |float <= 33.75 %}
           NNE
           {% elif 33.76 <= states('sensor.netatmo_wind_angle') | float  <= 56.25 %}
           NE
           {% elif 56.26 <= states('sensor.netatmo_wind_angle') | float  <= 78.75 %}
           ENE
           {% elif 78.76 <= states('sensor.netatmo_wind_angle') | float <= 101.25 %}
           E
           {% elif 101.26 <=states('sensor.netatmo_wind_angle') | float  <= 123.75 %}
           ESE
           {% elif 123.76 <= sstates('sensor.netatmo_wind_angle') | float <= 146.25 %}
           SE
           {% elif 146.26 <= states('sensor.netatmo_wind_angle') | float  <= 168.75 %}
           SSE
           {% elif 168.76 <= states('sensor.netatmo_wind_angle') | float <= 191.25 %}
           S
           {% elif 191.26 <= states('sensor.netatmo_wind_angle') | float  <= 213.75 %}
           SSW
           {% elif 213.76 <= states('sensor.netatmo_wind_angle') | float <= 236.25 %}
           SW
           {% elif 236.26 <= states('sensor.netatmo_wind_angle') | float  <= 258.75 %}
           WSW
           {% elif 258.76 <= states('sensor.netatmo_wind_angle') | float <= 281.25 %}
           W
           {% elif 281.26 <= states('sensor.netatmo_wind_angle') | float  <= 303.75 %}
           WNW
           {% elif 303.76 <= states('sensor.netatmo_wind_angle') | float  <= 326.25 %}
           NW
           {% elif 326.26 <= states('sensor.netatmo_wind_angle') | float <= 348.75%}
           NNW
           {% elif 348.76 <= states('sensor.netatmo_wind_angle') | float  <= 360.00 %}
           N
           {% endif %}"
I always get back ‘N’. Even if I know the wind is blowing from the South. It must have something to do with the attributes of sensor.netatmo_wind-angle because the reading of this sensor is: SE(132°) But how do I split that up? Can someone help me with the correct code?
