sjee
June 9, 2018, 7:24am
1
I’m struggeling to understand the data_group and element in the new netdata component (HA 0.71). For example I tried:
system.net:
element: in
and
system.net:
element: received
But I get and error; Sensor is not available: system.net
Using system.ipv4 results in an error; netdata: Error on device update!
Same here.
Thought this would work:
hddtemp_local.disks_temp:
element: sdd
But nope
sjee
June 9, 2018, 7:50pm
3
Maybe @fabaff can help us out on this.
fabaff
(Fabian Affolter)
June 9, 2018, 9:24pm
4
Unfortunately are there at least two bugs:
Multiple entries for the same resource will not work. Doesn’t pass configuration validation.
resources:
cpu.cpufreq:
element: cpu0
cpu.cpufreq:
element: cpu1
There are some deviation in the naming which I didn’t caught during the Beta. Like for hddtemp
"hddtemp_local.temperatures":{
"name":"hddtemp_local.disks_temp",
"context":"hddtemp.temperatures",
"units":"Celsius",
"last_updated":1528578157,
"dimensions":{
"sda":{
"name":"sda",
"value":45
@LarsNorgaard used hddtemp_local.disks_temp
which is shown in the frontend but in the response it is
. Thus the sensor is not working.
This seems also be the case for network metrics.
"system.ipv4":{
"name":"system.ipv4",
"context":"system.ipv4",
"units":"kilobits/s",
"last_updated":1528578181,
"dimensions":{
"InOctets":{
"name":"received",
"value":2.4819415
"OutOctets":{
"name":"sent",
"value":-2.4589827
I will try to fix it in the next couple of days and include it in a bugfix release if possible. I’m sorry for the inconvenience.
As an ugly work-around access http://[IP_NETDATA_INSTANCE]:19999/api/v1/allmetrics?format=json
with your browser then you will get the raw data that is used. Search for the data_group
and check the names of the element.
fabaff
(Fabian Affolter)
June 9, 2018, 9:25pm
5
I opened an issue to track this:
opened 09:23PM - 09 Jun 18 UTC
closed 10:42PM - 18 Sep 18 UTC
Home Assistant release with the issue:
0.71
Operating environment (Hass.io/Docker/Windows/etc.):
all
Component/platform:
https://www.home-assistant.io/components/sensor.netdata/
Description of problem:
Multiple entries for the same resource will not work as they don't...
waiting-for-reply
Before I had
- platform: netdata
host: 192.168.1.239
resources:
- disk_free
- memory_free
- system_load
what is the correct configuration now, I do not understand it from the docs
As @fabaff said, go to the API json link: [netdataIP]:19999/api/v1/allmetrics?format=json
and search for the data you want to show.
Ie. search for system.cpu
on that api json link and you will see the element you need is called system
If you want to show available ram you’ll have to search for mem.available
and see that the element you need in your yaml is called MemAvailable
- platform: netdata
host: 192.168.1.10
resources:
system.load:
element: load15
system.cpu:
element: system
hddtemp_local.temperatures:
element: sdd
mem.available:
element: MemAvailable
thanks, you know which is the command for disk availablle (free amount of HDD?)
This?
disk_space._run:
element: avail
Yes, but I would use disk_space._
instead. That one should give you the available disk space for the root drive.
Note though that it only shows the size of the drive and not how much space is free.
Well I need to know the free space, that’s the whole point for the need of a sensor
fabaff
(Fabian Affolter)
June 11, 2018, 6:43pm
11
Docs update is on the way
home-assistant:current
← home-assistant:netdata
opened 06:03PM - 11 Jun 18 UTC
Darbos
(Darbos)
July 1, 2018, 12:00am
12
Im not sure if that doc update has made it or not I just seen these docs for the first time. But its not very clear. I can see netdata json, Id like to monitor cpu/memory/network/disk can someone shoot an example out? its an ubuntu 16.04 box…
thanks
uiguy
November 12, 2019, 9:10am
13
sorry to revive an old thread, but I am battling to get this component configured 100% correctly.
Can I just ask for clarification that the element is marked “A” in the pic or is it “B”?
Thanks for any help…
