Netdata integration not working
having trouble with netdata … this integration has working for sometime and i noticed after upgrading to 0.100 that the sensor is undefined (below is configuration snippet ) and example error messages from log
any ideas what is wrong/bug?
# Netdata
  - platform: netdata
    host: 192.168.1.123
    resources:
      cpu:
        data_group: system.cpu
        element: user
  - platform: netdata
    host: 192.168.1.235
    resources:
      cpu:
        element: user
2019-10-14 12:23:03 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.netdata
2019-10-14 12:23:08 ERROR (MainThread) [netdata] Can not load data from Netdata
2019-10-14 12:23:08 ERROR (MainThread) [homeassistant.components.netdata.sensor] Unable to retrieve data from Netdata
2019-10-14 12:23:08 WARNING (MainThread) [homeassistant.components.sensor] Platform netdata not ready yet. Retrying in 150 seconds.
Hey man, did you ever get this working? I’m having similar issues…
Not sure whether I had same errors, but this is what helped…: access to Netdata is limited to localhost by default. You need to modify the web section of the config file (in my case /etc/netdata/netdata.conf) to allow access from other computers. Example:
[web]
allow connections from = localhost 192.168.1.*
allow dashboard from = localhost 192.168.1.*
The first parameter limits general access to Netdata. The second parameter allows access to the dashboard.
After changes you need to force Netdata to reload:
/etc/init.d/netdata reload
