Steps to reproduce:
- The Netdata node (PC with netdata client installed) must be available.
- Specify a couple of sensors for Netdata in configuration.yaml:
- platform: netdata
host: !secret vmdebian_ip
port: '19999'
resources:
cpu_softirq:
data_group: cpu.cpu0
element: softirq
icon: mdi:cpu-32-bit
cpu_user:
element: user
- Restart HA.
- Enjoy added Netdata sensors in Lovelace.
- Turn off the Netdata node (that PC).
- Watch in HA how Netdata sensors are “unavailable”.
Now the not funny part:
7. Restart HA.
8. Note that all Netdata sensors have disappeared - the Lovelace cards show errors.
OK, I understand that Netdata sensors are not created in HA in case “Netdata node cannot be found”.
What is the best practice in that case?
What I can do is:
- Create template sensors like:
sensors:
vmdebian_ram_used_persistent:
value_template: "{% if not is_state('sensor.vmdebian_ram_used','unavailable') -%}
{{ states('sensor.vmdebian_ram_used') }}
{%- else -%}
{{ states('sensor.vmdebian_ram_used_persistent') }}
{%- endif %}"
- Use in Lovelace these “persistent” sensors - they will be always present.
But may be there is a better solution?
Update:
Also, there may be a problem with “unit_of_measurement”.
For netdata sensors the unit is determined by the Netdata addon and MAY BE dynamically changing (I think so). So you only can speculate which units to specify for the manually made “persistent” sensors.
